130 to 430 Headunit Swap - Jeep Patriot Forums
post #1 of 6 (permalink) Old 06-16-2017, 02:25 PM Thread Starter
Your Neighborhood 2WD Rep
Brohio's Avatar
Hey gang -
My new Pat does not have the 430 system that I liked from my first Pat. I just have the regular 130 unit.
I found a decent deal on one on eBay, and was planning to swap it out. From what I have researched it should swap just fine, but wanted to run through the steps to make sure I did not miss anything. Any help would be appreciated, as I know a few people here have done this in the past.
eBay Link: Jeep Chrysler Dodge MyGig 430 RBZ Low Speed Touchscreen Display Radio CD OEM
To make the switch -
remove old radio
put 430 in
use provided antitheft code to activate head unit
then I'm all set right? I do not need to buy any additional wiring because the existing wires from the 130 just plug right in?
My eventual goal is to hook up a backup camera to the headunit, and my assumption is that since this one is from a 2016 Pat that it can receive the backup camera as long as I take it to the dealer and have them activate the backup feature on the unit. Is that correct?
As always, thanks for the help!
CURRENT: '17 Patriot Sport SE 4x4
PAST: '12 Patriot FWD Altitude Edition
Mods- 7" Stubby Antenna, Mopar Cargo Organizer, X2 Green RockyMount Euro PitchFork Bike Mounts
Brohio is offline
post #2 of 6 (permalink) Old 06-16-2017, 07:20 PM
I'm not knowledgeable on radio swaps--there's a lot of info on this forum. Regarding the back-up camera, you'd most likely have to run the video feed, along with 12v power from the b/u lamps all the way to the front. Make sure you get that overlay that covers the hatch handle, it has the mount for the camera in it.
Good luck--keep in touch!
Jack Allwardt, Bonney Lake (Tehaleh area), WA; "recovering Californian"; (REPEAT Patriot Owner...'08 Limited and a '16 High Altitude), Retired engineer, US Army veteran, Member: American Legion, Veterans of Foreign Wars, Central Valley Vietnam Veterans, Enumclaw (WA) Lions Club. Former vintage military jeep owner, instrument rated commercial pilot, ag pilot, vintage aircraft restorer and test pilot.
post #3 of 6 (permalink) Old 06-17-2017, 09:55 AM
14jEEp's Avatar
Hey Brohio
I swapped my 130 for a 430N in about 10 minutes. Plug and play. Because I opted for navigation, I confirmed my antenna was GPS compatible prior to install. Not sure on the back-up camera component because my 2014 is not pre-wired for that. Cheers.
<font color=White>_________________________</font>. .... . . . . . . . . . . . s l i g h t l y o n t h e b e a t e n p a t h
14jEEp is offline
post #4 of 6 (permalink) Old 06-17-2017, 02:12 PM
As long as its a low can-bus speed unit (which it looks like it is,) and you get the 4 digit unlock pin from the seller (for post-2011 units, i believe?) Then it should be plug-and-play.
breadtruck is offline
post #5 of 6 (permalink) Old 06-19-2017, 08:39 AM Thread Starter
Brohio's Avatar
Originally Posted by 14jEEp View Post
Hey Brohio
Did you have an existing antenna? Or can the 430N use the sat radio radio antenna as a GPS signal?
The main reason I did not go with a 430N was because I did not want to install another antenna.
Brohio is offline
post #6 of 6 (permalink) Old 06-19-2017, 09:40 AM
The only difference I see is the sat radio is mounted on the roof, and the nav is mounted on the forward part of the dash. As both items are in the same wave-length, they will work for each other--now the connectors are a different story--something that will have to be checked--and there are adapters out there. I found one several years ago that connected to my sat radio antenna and then to a gps that required an outside antenna.
