Hey guys hoping someone can help i bought an 08 patriot a couple months ago and since i bought it the passenger side headlight hasnt worked. Well i replaced the bulb nothing..i replaced the bulb socket still nothing?? Whats going on how do i fix this problem
When you have a problem with these symptoms--neither high nor low beam work--what's the common denominator? The GROUND, of course. Follow the wiring to the lamp socket and see where the third wire goes....might not be easy--but Patriots are known to have weird ground problems--and a large ground lives--under--the battery box, very susceptible to acid corrosion. Good luck and let the forum know what you find.
