2014 patriot latitude: My rear turn signal is turning on but not blinking. the dash dings and blinks fast as if the bulb is out. the front works fine. I haven't tried changing the bulb since it is turning on. I can't find any info on a relay associated with this signal, and I would assume that if it were a relay the front would have a problem too. What could fix this?
There are no relays, just try a new bulb. I had the same problem in the front...the bulb was on when the lights were on, but didn't blink. I replaced the bulb and it worked again.
Please don't ask how to check the blinker fluid . . .
And pleeze oh pa-leeze don't let croat sell you any. (I've heard he has lots that he bought from somebody else on this site)
