New tire for Jeep Patriot 2013 - Jeep Patriot Forums
post #1 of 8 (permalink) Old 09-18-2016, 05:51 AM Thread Starter
Hi all,
I have a question about tire size. I have a Patriot 2013 and tire size is 205/70R16. Can I replace with 215/70R16?
batam9121989 is offline
post #2 of 8 (permalink) Old 09-18-2016, 06:36 AM Thread Starter
Or Can I use 215/65R16 tires?
post #3 of 8 (permalink) Old 09-18-2016, 10:33 AM
This would be a better choice, as your speedometer will still be fairly accurate.
That phucker is offline
post #4 of 8 (permalink) Old 09-18-2016, 06:06 PM
Either should fit. My snow tires are 215/65-16s. The speedometer/odometer differences is so slight it hardly matters.
post #5 of 8 (permalink) Old 12-27-2016, 10:47 AM
silverflash's Avatar
my 2013 4x4 fd1 5spd came new with 17" wheel package.
i decided after the tires wore out to go to a 16" wheel and the 215/70R16 tire. i hated the gy wranglers... super noisey. i went with the yoko geolander ats. this tire is exactly the same outside diameter as what came off my jeep in the 17" size. so no speedo issues there. I gained some sidewall which helped the ride and helps more in offroad/rocky situations- though my offroading is limited to a steep creek gravel mountain road with some rocks sticking up an inch or so here and there that i have to nagivate around. but rubber will give before metal will.
i like the look way better. the feel way better- who puts low profile tires on a 4x4 vehicle come on- and it seems more jeep-like. i also lost some weight on each corner as the aftermarket wheels weigh about 4 lbs less per wheel- went with drag 9 wheels from discount tires. The tires got heavier but no by much, like 1 lb, and that is more than offset by less metal wheel weight....that means i lost no low end torque and in fact gained a hair i'd bet and it's easier on the wheel bearings and junk on the front end- less weight and more shock absorbing rubber....
2013 patriot sport 4x4 2.4 5spd FD1 True Blue, Willy's Overland edition
215/70R16 Yoko Geo ATS on Drag 9s, a/c
front and rear wet okole seat covers, front and rear rugged ridge floor mats, cargo cover,cargo carpet, front custom cut splash guards, rear window crank rattle-delete mod.
silverflash is offline
post #6 of 8 (permalink) Old 02-17-2017, 09:50 AM Thread Starter
and can I keep use same wheel or I have to buy new one to fit with 215/65R16 tires
post #7 of 8 (permalink) Old 02-17-2017, 04:39 PM
If your present tires are 16" and your new tires are 16" you can use the same wheels.
post #8 of 8 (permalink) Old 02-25-2017, 11:55 AM
Absolutely yes you can use it . My father-in-law has same car and he uses it
Liam Antony is offline
