15" Wheels and 30" tires on your Patriot (no spacers): Test Fit Results - Jeep Patriot Forums
post #1 of 407 (permalink) Old 03-06-2013, 04:55 PM Thread Starter
Supporting Vendor
Discount Tire's Avatar
Hello everyone,
We've been trying to find a great 15" option for the Patriot and with the help of a fellow forum member we've done just that. In fact, we've found 3 great 15" options for your patriot. Check it out.
Like we mentioned in the Discount Tire wants your help: Anyone running 15" Wheels? thread, our internal fitment guide is telling us that a 16" wheel is the smallest diameter that will fit the Patriot. After looking at the Patriot's brake dimensions and at the dimensions of some of our 15x7 0mm offset aftermarket wheels, we decided it was time to test fit. In looking at the wheel specs we discovered that a 15x7 with a 0mm offset should sit pretty similar to a factory wheel with a 32mm (1.25") wheel spacer. If this fit over the brakes of the patriot, running a wheel with these specs would give the vehicle owner the chance to run a wider and taller tire without the use of a wheel spacer.
Before I get to the results some of you may be asking, "Why would anyone want to run 15" wheels on their Patriot?"...
Here's a few reasons... First, if you have been looking for an off road tire option some of you may have discovered that there are not a lot of 16" or 17" off road tire models or sizes to choose from for the Patriot. 15" on the other hand, offers quite a few off road tire options. Also, downsizing to 15" is also great for off road performance. When compared to 16" and 17" tires of the same diameter, a 15" tire gives more sidewall height for better off-road performance and handling when aired down. 15" tire and wheel combinations may also save you some money at the pump. Depending on the wheel you choose, a 15" alloy wheel and tire combinations typically weigh less when compared to larger diameter wheel and tire set-ups. This, un-sprung weight savings translates into fuel savings. note* If fuel savings is one of the main reasons you are considering running a 15" wheel and tire set up we recommend running an alloy wheel over a steel wheel. Best of all though, 15" tires are typically more economical so when you're due for your next set you'll have more money left over to spend on other Jeep mods
With the gracious help of a fellow forum member, aroundincircles, we were able to test fit a few 15" wheel models on the Jeep Patriot along with a few larger tire options (compared to stock). Here's what we found...
RESULTS of TEST FIT:
The 15x7 ET0 (4" BS) Unique 297, 15x7 ET0 (4" BS) Cragar Soft 8, 15x7 ET0 (4" BS) MB TKO, and 15x7 ET0 (4" BS) MB Chaos 5 all cleared the Patriot brakes with plenty of room and DO NOT require wheel spacers. The sizes we test fit were 225/75-15, 235/75-15, and 30x9.50-15. We selected these sizes as a lot of the members here are lifting their Patriots and running 29" + tall tires. Please see pictures below for notes.
Links to Wheels that fit:
Unique 297: http://www.discounttiredirect.com/di...eeppatriot.com
Cragar Soft 8: http://www.discounttiredirect.com/di...eeppatriot.com
MB TKO: http://www.discounttiredirect.com/di...eeppatriot.com
MB Chaos 5 (black): http://www.discounttiredirect.com/di...eeppatriot.com
MB Chaos 5 (silver): http://www.discounttiredirect.com/di...eeppatriot.com
Links to Tires tested:
225/75-15 Tire Options: http://www.discounttiredirect.com/di...eeppatriot.com
235/75-15 Tire Options: http://www.discounttiredirect.com/di...eeppatriot.com
30x9.50-15 Tire Options: http://www.discounttiredirect.com/di...eeppatriot.com
Now on to the pictures!
*Please note that aroundincircle's Patriot has a 2-1/8" lift and PWM done. Also, any one of these wheels can be used with any one of these tire sizes to create the combination you are looking for.
15x7 ET0 MB TKO mounted with the 225/75-15 General Grabber AT2
Notes: This set up may fit non lifted Patriots IF the owner is willing to cut the pinch weld and trim the fender liner in the front fenders. No rear fender modification is required.
15x7 ET0 Unique 297 mounted with the 30X950R15 Discoverer AT3
With a 2 1/8" lift this tire requires the pinch weld to be modified (cut or bent) it also requires some modification to the front fender liners.
15x7 ET0 MB Chaos 5 mounted with the 235/75R15
Notes: This fitment requires a 2 1/8" lift, Pinch weld modification and fender liner trimming.
Low Prices! More Choices! FREE Shipping!
At The Store: www.discounttire.com
To Your Door: www.discounttiredirect.com
Sales and Technical: 1.888.459.4080
Found a Lower Delivered Price?
Need Tires for Your Camper or Trailer?
Useful Links:
Tire Calculator
Current Promotions
Interactive Wheel System
Wheels & Tires 101
Discount Tire is offline
post #2 of 407 (permalink) Old 03-06-2013, 05:05 PM
These are probably my favorite:
15x7 ET0 MB Chaos 5 mounted with the 30x9.50-15 DuraTrac
Except I would have the wheels in black.
On I side note, probably should have run the patriot through a wash first...
post #3 of 407 (permalink) Old 03-06-2013, 05:14 PM Thread Starter
Supporting Vendor
Thanks again for your help! And as for the dirty part... Its a JEEP!
Useful Links:
Tire Calculator
Current Promotions
Wheels & Tires 101
post #4 of 407 (permalink) Old 03-06-2013, 05:14 PM
The Sticker Whore
Kenny-g's Avatar
AWESOME! I know aroundincircles...and I know that he probably didn't wanna leave without a new set of tires and wheels, probably the DuraTracs haha this makes me reconsider keeping my TJ Rubicon MOAB wheels (16") and looking for a nice 15" wheel for better tire options! I love the MB TKO wheels! They're sexy as hell. My Rubi's are already payed off though.
*Edit: go figure he said the DuraTracs haha I'm good
*Edit again; I didn't even see his post before making mine...so now I look dumb
LOST YETI
Bright White '13 Jeep Wrangler Sport "Lee-Roy2.0"
Rough Country Hybrid Stubby Front Bumper w/ Fog Light End Caps | Trimmed Flares | 3C2X Industries Pods (4 sets now)
285/70/R17 Falken Rocky Mountain ATS IIs on Rubi MOABs | Removed Rear Bumper | JKUR shocks and springs installed
Spiderweb Shade | GripCords.com black and glow-in-the-dark white paracord grab handles | LED Rock Lights
Cobra 19 DX IV CB | Firestik 4' Antenna | Rugged Ridge tailgate antenna mount | OTRATTW switch | sPOD
Kenny-g is offline
post #5 of 407 (permalink) Old 03-06-2013, 05:19 PM Thread Starter
Supporting Vendor
You called it Kenny! I don't blame him either they are a great looking tire and a lot of wrangler guys wheel the heck out of them. Some people complain about them only having a 2 ply rated sidewall but honestly I think that's more from those not running them, I don't remember reading any complaints from anyone that is actually running them.
Useful Links:
Tire Calculator
Current Promotions
Wheels & Tires 101
post #6 of 407 (permalink) Old 03-06-2013, 05:23 PM
The Sticker Whore
Kenny-g's Avatar
Everyone loves them and BFG Mud Terrain KM2s...those have to be the two most popular tires on the market right now, hands down.
LOST YETI
Kenny-g is offline
post #7 of 407 (permalink) Old 03-06-2013, 05:33 PM
The Sticker Whore
Kenny-g's Avatar
PS; I am a page administrator for JeepPatriot.com's Facebook page and posted a link to this thread for y'all
LOST YETI
Kenny-g is offline
post #8 of 407 (permalink) Old 03-06-2013, 05:35 PM Thread Starter
Supporting Vendor
Very cool. Thank you. We hope it helps the Patriot communities out.
Useful Links:
Tire Calculator
Current Promotions
Wheels & Tires 101
post #9 of 407 (permalink) Old 03-06-2013, 05:40 PM
I think everybody should chip in $10 for my troubles
post #10 of 407 (permalink) Old 03-06-2013, 05:41 PM
The Sticker Whore
Kenny-g's Avatar
Lol somethin like that Karl...
LOST YETI
Kenny-g is offline
post #11 of 407 (permalink) Old 03-06-2013, 05:41 PM
dixiedawg's Avatar
Another Knowledge Base thread
You can go fast, but I can go anywhere
dixiedawg is offline
post #12 of 407 (permalink) Old 03-06-2013, 05:44 PM
The Sticker Whore
Kenny-g's Avatar
Would a 3.75" backspacing 15" wheel work for us w/o spacers?
LOST YETI
Kenny-g is offline
post #13 of 407 (permalink) Old 03-06-2013, 06:05 PM
Why so serious?
BondiBlue's Avatar
Man those 30" tires sure do look nice!
BondiBlue is offline
post #14 of 407 (permalink) Old 03-06-2013, 06:10 PM
The Sticker Whore
Kenny-g's Avatar
I'm uber tempted to sell my 5 16" TJ Rubi MOABs and buy 4 Cragar V-5 15x7 wheels cause the tire prices would be better plus I'd only have to buy 4 tires instead of 5! I just don't know if the 3.75" backspacing would fit w/o spacers.
LOST YETI
Kenny-g is offline
post #15 of 407 (permalink) Old 03-06-2013, 07:01 PM Thread Starter
Supporting Vendor
That depends on the width but assuming they are 15x7, and they clear the brakes, they'd stick out about 1/4" further than the 15x7 0mm offset (4" backspace) wheels we test fit.
If they are wider than 7" they may limit how tall of a tire you can run as they may stick out too far and shove the front tires into the corners of the body when you turn hard.
Useful Links:
Tire Calculator
Current Promotions
Wheels & Tires 101
