Simple Mods, will they Void the lifetime Warranty? - Jeep Patriot Forums
post #1 of 4 (permalink) Old 03-13-2008, 04:45 PM Thread Starter
ldjbuff's Avatar
Send a message via MSN to ldjbuff
Hey Eveyone,
I plan on putting in a K&N Airfilter and a Catback exhaust system on my Pat.
Will that void my lifetime Warranty?
Also doesnt it void the warranty if you put on bigger tires? More taxing on the motor? or even a lift?
Thanks in Advance
-Lucas
~Idaho~08 Patriot FD I Green 5 speed, 17" Rims, Moon Roof and Tow Package~ MODS- K&N Airfilter
ldjbuff is offline
post #2 of 4 (permalink) Old 03-13-2008, 05:11 PM
UP_2Tracker's Avatar
The way I understand the law in Michigan (and maybe the rest of the US) is that they have to reasonably prove that the modification contibuted to the failure (or something like that anyway).
If you put on much bigger tires (not possible on the pat) and break an axle, it likely wouldn't be covered by a warranty, but if your engine had problems it would most likely still be covered.
Make sure you keep any original parts in case you have problems. You can easily swap them to the original if you have to, but this might be too difficult in the case of something like a lift (which could only void suspension components I think).
Anyone else have first hand experience here? I've never put the theory to the test.
Last big adventure: Wyoming Range (I took the pic in my avatar from the top of Lookout Mountain)
UP_2Tracker is offline
post #3 of 4 (permalink) Old 03-13-2008, 06:08 PM
Matter of opinio
Have had a neon with Aftermarket struts and Mopar Performance Spark wires
couple Dealers stated that was modified they would not cover headgasket repair.
Had to go to a third dealer before I found a dealer to cover it under warranty
Some dealers will claim that the excess dirt on the car changed the aerodynamic properties of the car and put an undo burden on the drivetrain,
hence voiding the warranty,
a stretch but you get the point
post #4 of 4 (permalink) Old 03-14-2008, 09:30 AM
Ollie18's Avatar
Send a message via AIM to Ollie18 Send a message via MSN to Ollie18
Know your rights before you let a dealer push you around...
http://www.semasan.com/main/main.aspx?id=60128
Here is the answer to your question:
The Magnuson-Moss Warranty Act may also be helpful. Under this federal law, you can sue on breach of express and implied warranties. The main point of interest here is that the Act says warranty coverage may not be conditioned upon the use of only the vehicle manufacturer's parts unless the parts are provided free of charge. In other words, use of a non-carmaker/OE product should not void your warranty unless it caused the problem.
Ollie18 is offline
