2009 Pat that won't start - any solution? - Jeep Patriot Forums
post #1 of 21 (permalink) Old 02-20-2010, 01:28 AM Thread Starter
Question 2009 Pat that won't start - any solution?
Just like in a past forum, I have a Pat that starts great the first time I get into it for the day and then, after I stop the engine at my first destination, get back in and try to restart it, it won't turn over. If I wait 5 minutes or keep trying to start it (which is taxing the starter) it finally turns over again.
This is happening more and more frequently and is getting really annoying since I'm a real estate agent and cannot function without a reliable car.
I've had it to the dealership and got the same old, "can't find anything wrong" and, "bring it in next time," only to have them say they can't find anything wrong again. ... the low juice on the battery may be clearing any usable data?
No, I'm not going to do my own diagnostics. My job already paid for the warranty, now it's their job to fix the problem.
My question: Did anyone ever find a solution to this problem?
ddcameron is offline
post #2 of 21 (permalink) Old 02-20-2010, 02:06 AM Thread Starter
BTW
It's a bare bones manual - no fancy locks and keys or anti-theft jazz.
post #3 of 21 (permalink) Old 02-20-2010, 02:36 AM
Annoying Member
robi454's Avatar
Send a message via Yahoo to robi454
Ok, this could be acouple of things, which hooking the car up to a diod will not point out because if the problem isn't occuring when the car is hooked up to the computer then it won't show up as a problem.
I am going to need some more information about what your car is doing when the problem occurs. When you get in and turn the key is there a clicking sound coming from under the hood? Is the motor turning over very slowly like when starting an old car on a dead battery? Is the car making no noise at all. Be very specific as to what is happening. The more information you give me the better.
Sometimes, war is the peaceful solution.
Everyone should believe in something…I believe, I’ll have another beer.
robi454 is offline
post #4 of 21 (permalink) Old 02-20-2010, 08:20 AM Thread Starter
It's the most basic model you can buy. 2wd, doesn't even have power locks (which I regret most hardily)
It never happens the first time I get into the car for the day. It happens the second time I try to start it, like after running into the store for a few moments.
It makes the standard noise a car usually makes like it's trying to start but doesn't have the giddy-up to do so - so, yes, like an old car with a crappy battery.
Does the noise seem like a slow attempt? No. It feels like it's really trying but, it just won't catch and start.
post #5 of 21 (permalink) Old 02-20-2010, 08:25 AM Thread Starter
And, thanks, btw.
post #6 of 21 (permalink) Old 02-20-2010, 08:58 AM
PCM
Last Summer we had a similar.....issue with out Pat. Same thing was happening to us. Would stall, but not hold a code in the history and seemed to never do it for the dealer. Finally I got frustrated, and dropped it off at the deal at night (right in front of the door, with a note on it "FIX IT OR KEEP IT")
Anyway, it stalled for the mechanic with the computer hooked up on his way home with it that night. WOOHOO!!
It end up being the process control module (PCM). It was under warranty as it was only a year one. My wife kept saying to people that the Pat was "brain dead" which I guess it was.
Might not be exactly what you are looking for, but any info is good info in my book..Good Luck!
Igor
Igorstien is offline
post #7 of 21 (permalink) Old 02-20-2010, 10:43 AM
Hitzy's Avatar
My wife's key fob died and the pat would not start. Everything would light up, just wouldn't turn over. Might be something wrong with the key chip or the reader in the jeep.
Hitzy is offline
post #8 of 21 (permalink) Old 02-20-2010, 11:02 AM
Yes! They had to replace that module as well....
Igor
post #9 of 21 (permalink) Old 02-20-2010, 12:12 PM
Annoying Member
robi454's Avatar
Your battery is not producing enough power to crank your engine after your engine has created high compression levels. When you let the car sit over night, it slowly decreases the ammount of compression inside of the engine. When you get in it first thing in the morning and it fires right up. However, after driving it for a little while then turning it off your engine has built up and stored up compression this makes it harder for you weak battery to turn over your engine. Your battery isn't dead so when they test it, it tests ok.
I have an old car that builds and stores so much compression that even a fully charged battery turns it over very slowly. When you get into your Jeep, turn the key to the on position and let it sit for about 30 seconds before trying to start it, then press the gas pedal all the way to the floor three times (quick pumps). Then attempt to start your jeep.
If this doesn't work let me know. You still need to take your vehicle in to the dealership, but this should release some of the compression so you can start your jeep.
robi454 is offline
post #10 of 21 (permalink) Old 02-20-2010, 06:53 PM
Boy George's Avatar
Could proly be any of the things mentioned above ... but you could also try a simple thing - take off the battery clamps and clean them (and the battery terminals) with a brass wire brush, then tighten everything back well again. Might be just oxidised contacts which won`t let enough power pass to the starter.
Boy George is offline
post #11 of 21 (permalink) Old 02-20-2010, 07:36 PM
ddcameron: I saw this same problem on a Saturn. The trouble was a faulty crank position sensor. The sensor tells the computer that the engine is turning over fast enough to start and then the computer enables the ignition module to fire the spark plugs. The reason it starts cold is that the sensor is affected by heat and becomes intermittant when heated. My sisiter-in-law paid a ton of money in parts that did not fix the trouble until she found a automotive technician who knew what they were doing. The hint was that it would start cold but not hot and not do it every day.
wpeck2 is offline
post #12 of 21 (permalink) Old 02-20-2010, 08:51 PM Thread Starter
Thanks so much everyone for the insight and robi454, I will definitely take your advice and see if it's a compression issue.
I'm bringing a copy of this thread with me when I take it in on Monday. It may irritate them but, if one of these suggestions is right, at least they'll know what to do if it happens to someone else.
I will report back when/if they tell me what they think is wrong.
post #13 of 21 (permalink) Old 02-21-2010, 10:48 AM
gnihcraes's Avatar
sounds like the old school problem of a bad winding in the starter. smack the started with a rock or hammer, and see if it starts. usually will on the old chevys, then you know the starter is stopping on a bad spot in the windings... causing it to not work.
2007 CVT2L OffRoad
gnihcraes is offline
post #14 of 21 (permalink) Old 02-24-2010, 09:10 AM
No it doesn't. Try rereading his problem.
sskelmar is offline
post #15 of 21 (permalink) Old 02-25-2010, 09:35 AM
gnihcraes's Avatar
whatever, still sounds like it could be the problem. Seen it many times, luck of the draw when the starter hits the bad winding... could be every day, could be every stop where to you turn it off... But hey its the internet, everyone is RIGHT ya know... You're right. that's not the problem. You fix it then.
Oh I see, you want me to Re-Read his problem that is 5 posts down in the thread, not the "first" post with none of the "information" in it...
2007 CVT2L OffRoad
