Manual Trans, won't shift into reverse gear. - Jeep Patriot Forums
 3Likes
  • 2 Post By pahiker
  • 1 Post By Blackmatter
post #1 of 9 (permalink) Old 01-17-2017, 03:43 PM Thread Starter
I just put my 08 manual into the garage. A few days ago while parking I couldn't shift into reverse. To clarify, the gearstick would not physically go down into the reverse position at all,yet all other gears worked normally. I took it for a quick spin in which I tried a 'double clutch' tech,...whether it worked or not the problem temporarily resolved until today. Nothing I tried today allowed the gearstick to go downright into reverse.
It's in the shop now, due to be diagnosed tomorrow. Any body with any insight so that I may compare it what my mechanic says?
jimjam89 is offline
post #2 of 9 (permalink) Old 01-17-2017, 04:22 PM
Was it problematic to get it into reverse before this happened, or did it shift fine and then pow - no reverse? My '16 sometimes needs a few attempts before it's in reverse. It will feel like it's in reverse, but when you let out the clutch it makes whirring and light grinding noises. A retry or two will usually get the job done. Never that that occur on the other cars I've owned.
2016 Patriot Sport, 5 speed manual, 4x4.
pahiker is offline
post #3 of 9 (permalink) Old 01-17-2017, 06:03 PM Thread Starter
I've had no problem getting it into reverse until this week. I've gotten pretty used to the shiftier, and at no time in the weeks leading up to now (or ever except 1 1/2 years ago) have I been grinding it into reverse or shifty sloppy. This is a bit different that what most are describing. For me the gear stick will go to the right, but it won't budge down a bit, except maybe to slip into 4th if I force it a bit.
jimjam89 is offline
post #4 of 9 (permalink) Old 01-17-2017, 07:49 PM
Blackmatter's Avatar
I have the same problem.
2016 Jeep Patriot 4x4
215/70/16 General Grabber AT2s
Blackmatter is offline
post #5 of 9 (permalink) Old 01-18-2017, 02:15 PM
Hi Blackmatter,
Are you working with a dealership to get this resolved?
Kori
Jeep Social Care Specialist
JeepCares is offline
post #6 of 9 (permalink) Old 01-19-2017, 02:29 PM
This doesn't help the original poster, but I had read that if you shift into 1st, then into reverse you won't have the occasional state of "limbo". I tried that today and so far it seems to work. Never had to do this on other vehicles, but may be a quirk of the T355 tranny.
nth256 and 5speed like this.
pahiker is offline
post #7 of 9 (permalink) Old 05-17-2017, 08:18 PM
The issue has gotten better at 18,000 miles. It's smoother now. Not sure why.
JeepCares likes this.
post #8 of 9 (permalink) Old 05-18-2017, 07:00 PM
5speed's Avatar
This is not unique to this vehicle. I've had it happen occasionally with many different makes during the past 50 years. Usually I just put it in reverse again, but sometimes it can be stubborn so shifting to 1st then reverse convinces it I want to go backward.
2017 Patriot Latitude, FWD, 2.4, 5sp, 430 radio/backup camera. 2016 Patriot Sport, FWD, 2.0, 5sp, air, power group. Mopar Splash Guards, Mopar cargo cover, AVS In-Channel Ventvisor, General Altimax RT43 tires, Curt Class III 13081 hitch, front windows tinted to match others, Sport driver's seat raised.
5speed is offline
post #9 of 9 (permalink) Old 05-18-2017, 08:13 PM
Definitely nothing new to jeeps--my Korean war M38 (3 speed) was the same way, must have something to do with the syncro-mesh gears...
Jack Allwardt, Bonney Lake (Tehaleh area), WA; (REPEAT Patriot Owner...'08 Limited and a '16 High Altitude), Retired engineer, US Army veteran, Member: American Legion, Veterans of Foreign Wars, Central Valley Vietnam Veterans, Enumclaw (WA) Lions Club. Former vintage military jeep owner, instrument rated commercial pilot, ag pilot, vintage aircraft restorer and test pilot.
manual, no reverse, standard, transmission
