CVT Overheats - Jeep Patriot Forums
post #1 of 23 (permalink) Old 12-29-2016, 09:43 PM Thread Starter
CVT Overheats
Son bought a Patriot 4x4 with a CVT a month ago. On a 2 hour trip the warning light came in and went into limp mode. The shops around here all say dealer only. Is there a chance it might be something simple or is the tranny shot?
Mrkeys is offline
post #2 of 23 (permalink) Old 12-29-2016, 11:36 PM
I doubt it's shot....
What's the mileage?
Is the right amount of fluid in there? (it could behave as described with too little OR too much cvt fluid in it)
Has the fluid ever been changed? (if not, it probably needs it now anyway after heating up)
Did it operate normally again after it cooled down?
Did it give an error code?
It's dealer only because the shops you asked don't know what to do. Many have had their cvt checked/serviced at a transmission shop instead of the stealership.
Search this site for threads on cvt limp mode.
post #3 of 23 (permalink) Old 12-30-2016, 09:38 AM
Hi Mrkeys,
Sorry to hear about this! If you decide to visit your local dealership I'd be happy to follow up with them for you if needed. Just PM our page with your VIN and let me know.
Andrea
Jeep Social Care Specialist
JeepCares is offline
post #4 of 23 (permalink) Old 12-30-2016, 06:37 PM
I have a 2015 Patriot "4x4" with FDII and CVT Trans. I Just got it back from the dealer for this reason. Both times that I've been on the 15 fwy in SoCal, the CVT overheated. Starts with a whine, then the light comes one, then you loose power to the car and have to pull over and wait for it to cool. This is a self-protect feature for the trans but it is sooooooooooo un-safe because you suddenly have to negotiate crossing over 4 lanes of highway with a limping car; there should be a lawsuit against Chrysler for this...... but anyway. I got it back and the dealer said the CVT was overfilled with fluid. This are their notes:
Unable to verify overheat concern. trans is overfilled. Scanned modules not DTC's. Fluid is at 60mm at 110 degrees.
set to 30mm at 180 degrees. road tested 3 miles all shifts normal. trans operates as designed.
So, if this is to be believed, the trans was severely over-filled based on the graphs(attached). I'll have to see how it does but from what I've been reading, this is common for these Jatco CTV transmisions; we might all be f!@*&.
bob15 is offline
post #5 of 23 (permalink) Old 12-30-2016, 08:25 PM Thread Starter
Thanks everyone! It has 184000 miles. It works fine after cooling down. Having a mechanic friend scan for codes tomorrow. Is that chart for a 2.4 4 wheel drive? How do you know the fluid temp??? I bought a dipstick at Oreilly's. Have no idea if the fluid has ever been changed.
Mrkeys is offline
post #6 of 23 (permalink) Old 12-30-2016, 08:52 PM Thread Starter
And just to verify, run through the gears and then check while it is running in drive?
Mrkeys is offline
post #7 of 23 (permalink) Old 12-30-2016, 09:02 PM
I'm going to say that since it had overheated, it would be a good Idea to change it. That chart is good for all Patriot cvt transmissions....but since we don't know the temp I fill mine to 35mm while at outside temp of about 70-75 degrees. If you'' notice, 35mm is in the acceptable range at any temp.
Dealer will charge you $2-300 to change the cvt fluid.....if you want to do it yourself you can spend about $75....you can use Valvoline cvt fluid from Autozone or where ever, it doesn't have to be mopar fluid.
check these threads....and good luck!
Transmission Service - Purchasing own fluid
Transmission temperature warning light
post #8 of 23 (permalink) Old 12-30-2016, 09:03 PM
Yes..........
post #9 of 23 (permalink) Old 12-31-2016, 11:17 AM Thread Starter
Ok I goggled extensively. How many quarts for a regular fluid change? Getting conflicting information.
Mrkeys is offline
post #10 of 23 (permalink) Old 12-31-2016, 12:03 PM
Best I can tell you is 4-6....some said they drained 6....I only got 4 but I pumped mine out through the filler tube with a cheap hand pump.
The main thing is, drain it and fill it back to aprx 38 or so mm at a low temp, before the fluid has time to heat up.
post #11 of 23 (permalink) Old 01-01-2017, 08:38 AM Thread Starter
Fluid level is fine. Still has a green tint and looks like it was just poured from a new bottle.Mechanic scanned and there were multiple codes pointing to a brake switch and tranny overheating. Plan is to add a tranny cooler. The brake switch might be linked to a cruise control/esp problem it has. Both are cheap. Found out the first tranny had been replaced at 38,xxx miles.
Mrkeys is offline
post #12 of 23 (permalink) Old 01-02-2017, 03:22 AM
As I previously mentioned, my CVT overheaded twice while on the 15 fwy in socal. The dealer checked it fluid level and it was grossly over-filled. Today, I decided to try to reproduce the issue and I'm happy to report that the issue did not occur today. It was much colder today than the day when the CVT overheaded but I think it was still a good test. Hopefully, I won't be having more problems with mine. Good luck on yours!
bob15 is offline
post #13 of 23 (permalink) Old 01-02-2017, 11:45 AM Thread Starter
Thanks! Glad it was a simple fix. Plan "B" or "C" is to drive an hour to the jeep dealer, wait 2-3 hours, give them $100+ for a diagnosis that might be correct, drive an hour home.
Mrkeys is offline
post #14 of 23 (permalink) Old 01-02-2017, 03:24 PM
My CVT has never acted like yours but when it gets hot around here in the summer (90F) my CVT tends to whine/hum a little, but that's only a few days in the summer. I suspect it gets hotter in SoCal or NC. My first CVT failed at 110,000. I've got more than that on my replacement and no problems.
If this is happening to you I think the tranny cooler is a good idea. Its a lot cheaper than a new tranny.
PS. I like my CVT and would buy another . . . if only I could.
RossoRacer likes this.
post #15 of 23 (permalink) Old 01-03-2017, 04:08 PM Thread Starter
Would be nice to have a temp gauge for the cvt. Wonder if anyone has figured out an easy way to do this??
Mrkeys is offline
