Anybody replaced their A/C clutch? - Jeep Patriot Forums
post #1 of 15 (permalink) Old 06-22-2016, 06:30 PM Thread Starter
I'm thinking mine is out. Anyone have some background on this job?
nth256 is offline
post #2 of 15 (permalink) Old 06-25-2016, 11:29 AM
Buy a new compressor. Changing clutches is very difficult, even with all the proper tools
Sent from my Vortec-powered Droid Turbo using Tapatalk
TrailBlazerZ71 is offline
post #3 of 15 (permalink) Old 06-25-2016, 11:30 AM
Turn your ac on and watch, you should be able to see the clutch cycle on and off
post #4 of 15 (permalink) Old 06-28-2016, 09:46 PM
What tools are needed? I have a 08 looks like the standard clutch removal tool won't work because there's no threads to lock into.
Jeedup is offline
post #5 of 15 (permalink) Old 06-28-2016, 09:53 PM
There's a picture of what I'm seeing. A 7mm socket fits it but has the dimple like a clutch removal tool should go there. No threads though...
Jeedup is offline
post #6 of 15 (permalink) Old 06-29-2016, 12:55 AM Thread Starter
Well... I don't think that's gonna happen...
The pulley still freewheels, which is good. I can turn the shaft about a quarter turn either direction with my fingers before it stops, but it feels like resistance more than a hard stop, so hopefully the pump is still okay.
I've never seen anything like this before.
Duly noted; I'd like to see if i can save the pump if possible, only because money is a big factor right now, but someone else pointed out that most likely, the pump seizing is what caused the hub to snap off in the first place, so I'm probably looking at a pump anyway.
Or maybe a trade-in... while my Patriot is still somewhat road-worthy.
That hub looks aftermarket, based on what I've seen online, but the tiny spindle nut in the middle looks just like mine. I'm sure someone else with more experience will be able to verify that. Good luck with yours.
nth256 is offline
post #7 of 15 (permalink) Old 06-29-2016, 11:49 AM
It always helps to give the year and engine of your vehicle. In this case, it seems that the air conditioner style changed maybe with the 2009 model year. Jeedup's picture looks to be of the 2007-2008 style.
My 2014 factory service manual looks more similar nth256's picture and says that clutch removal is possible with the compressor on the engine, but you may need to loosen or remove the compressor mounting bolts for better access. You simple grab on to the pulley, remove the center bolt, and tap the pulley to gently work it off the shaft. Snap ring pliers are needed to disassemble the clutch assembly, a moot point in this instance.
post #8 of 15 (permalink) Old 06-29-2016, 12:26 PM Thread Starter
Mine is a 2008 (which was listed in the old forum format, but seems too have been dropped from the little block of identity info.)
nth256 is offline
post #9 of 15 (permalink) Old 06-29-2016, 08:41 PM
Thanks for the info. I do have a 2008. I tried holding the pulley in place while trying to turn that bolt but I don't have enough ass in my arms. I'll try a banded oil filter next week.
Jeedup is offline
post #10 of 15 (permalink) Old 06-30-2016, 10:48 AM Thread Starter
Best bet is probably to spray that little bolt with some PB Blaster or, at the very least, WD-40. Soak it, let it sit an hour, soak it again, let it sit again, then give it another shot.
nth256 is offline
post #11 of 15 (permalink) Old 06-30-2016, 10:53 AM Thread Starter
Is your service manual in PDF format? Any chance I could take a peek?
All i was ever able to obtain for my '08 was the wonky CD version of the service manual, which i could never get to work.
nth256 is offline
post #12 of 15 (permalink) Old 06-30-2016, 06:10 PM Thread Starter
Found a PDF service manual for a 2007 Dodge Caliber (same AC compressor for both, so close enough!)
It doesn't use a magnetic clutch! In fact, the stupid "clutch" is meant to break away in case of seizure!
This doesn't look good, guys...
nth256 is offline
post #13 of 15 (permalink) Old 06-30-2016, 10:17 PM
Nice find with the manual. A lot of good information. Autozone sells a replacement bearing for this compressor. Part number is mt2238. Bought one a couple of days ago, haven't installed yet though.
Jeedup is offline
post #14 of 15 (permalink) Old 07-01-2016, 01:09 AM
nth256, excellent find. Your info above seems to be correct.
My apologies, because my 2014 manual has two air compressor versions, one having a removable/serviceable hub/pulley assembly that I commented above on. The version I referenced is ONLY available on the diesel engine, and it was not too difficult to follow the manual and end up in the wrong air compressor by mistake. Again, my apologies.
post #15 of 15 (permalink) Old 07-01-2016, 09:33 AM Thread Starter
No worries! It's all a learning experience.
nth256 is offline
